RB igniter
HotWIRED
Anyone know how to check the igniters? The RB won't start-up. It'll just crank, but won't light up. There's fuel coming, there's power, but no spark. Is there something else I so check, also? Thanks.
NeedCAforS13
Car: CA swapped S13 coupe
sounds like either the ignitor or maybe the CAS...try another ignitor that you know works...other than that i dunno?
we were having trouble with my friend's CA18 and we ended up using my CAS and it worked...
Sean
HotWIRED
What is CAS??
NeedCAforS13
crank angle sensor...the round thingy on the front of the cam gear cover...with the mitsubishi diamond star logo on it:D
Sean
FAST-DATSUN
Check power to the Ignitor 12V if there is power remove the CAS and turn it by hand. The plugs should spark and injector work, if not check power to the CAS and out put from it to the computer...
HotWIRED
Thanks for the help, I checked the ECCS and it came up with a 55. I checked the CAS, there's power to it. I can hear the injectors open, but no sparks. I checked the power wire going to the ignitor, theres power. Then I hooked up the ignitor back on with seven pin plug on and the six pin plug off and result, no power.
veilsideS14
Is the main ignition relay down by the ECU working properly?
HotWIRED
I'll check. I'll switch them out and use the stock ones.
