JonPowell »
https://forums.nicoclub.com/jonpowell-u5113.html
Mon Nov 03, 2003 6:56 pm
The only real way to get them apart, with the engine still installed, is to pull the head on the engine, that way you can loosen the motor mounts and let the whole block roll back into the tunnel. I found that out after I had the head blow up on my RB25DET and pulled the head first.
