mixeds14 wrote: 75lb injectors
They are top feed injectors, neos also come with top feed.xracerx972 wrote:mixeds14 wrote: 75lb injectorsWhere did you find high impedance 787.5cc side feed injectors? Just out of curiosity..
Anyway, I wouldn't change the head bolts or HG if your goals are 500hp or below. Your weakest link (which is well documented) is your ring lands, bottom end hardware and your oil pump crank collar. Being a NEO, you may be lucky and have the revised collar.
I know people that beat the #### out of their internally stock 25's and they just take it. The main thing to ensure is oil pressure and water cooling capability. Plenty of 411 on all of these topics. Hope this helps.
Oh sorry, that's the easy part. Wait until the engine is cool. Loosen the head bolts from the ends of the block, while alternating, and work your way towards the middle. The ARP studs have a #4 allen key on top and you lightly lube them and lightly tighten them in place. Finish up by installing the ARP nuts in the order shown in the FSM but using ARP's torque specs. I like to tighten them down part way first and then go for 90% torque and then final torque everything, but I'm anal.mixeds14 wrote:guess bolts will do for insurance. However my question dint get answer on how to go about changing the bolts without distorting the oem head gasket.
Matt, glad u sold the car to someone that's actually Goin to take good care of it and the time/work u put in to it.
Also I will be hitting u up on the fc tune in the next month or so..
