klh6686 »
https://forums.nicoclub.com/klh6686-u16180.html
Sat Aug 05, 2006 2:18 pm
Hello, I've been following the RB motor on several diff forums for quite some time now and have always seen references to the RB head cooling mod, mainly done on gtr's. I understand what it is for i am just unsure of how to apply it on my RB25 head. Now my understanding is that the way coolant flows stock (mainly the coolant tube on the intake manifold) isn't the most efficient way to route coolant and so the manifold gets tapped for new lines. Is it done in addition to the coolant pipe on the bottom of the mani or would it be best to replace that w/ three flanges w/ lines running to them? Where do the lines run to, the heater hose outlet next to the thermo? basically im trying to get a better understanding so that i can apply it to the motor that i'm currently building. I am currently in the process of performing oil modifications as per SydneyKids (SAU) instructions including oil restrictors, drain at the back of the head, oil cooler, etc. Also as a sidenote, does anyone know how to correctly remove the vct on the RB25? Thanks Guys
