rb guy help
boomers04
Car: none
Ok so i have an rb25det with a greddy intake and a new top mount mani with a newly rebuilt holset H1C off a 93 dodge. Oil is backing up into the turbo and burning out the exhaust, and can not figure out what is going on. The holset oil return relies on gravity to get it back to the engine, there is not kinks or sharp turn in the feed line, it is made out of 3/4 inch copper tubing. We pluged the engine hole and just let the oil com out the turbo with out the feed line and it was pumping great. Filled a urine cup in like 7 sec. there is nothing clogging the hole to the engine. I put an oil restrictor on it with a .060 hole to limit the oil pressure, heard that holsets need that. Please help this is the last part to a 6 month project. The only thing is that there is back pressure some where. could not figure hot to post a pic , but will be glad to email.Sorry for the long post.
devil_child
might be dumb of me but a restrictor on the inlet right....
and the drain is facing down right?
boomers04
Car: none
ya
matafied
Car: 1989 240 rb25det 1992 240 rb25det
ive seen this on a different turbo (sc61) on an rb, because of crank case pressure, motor was not breathing properly. this particular rb had a small air fiter on the valve cover and it got clogged up with oil and the motor started building pressure and caused oil to back up into the turbo and was burnning it out exhaust, so hope this helps
boomers04
Car: none
what did he do to fix this, get a bigger air filter.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
in other words, how are you venting your crankcase pressure? Factory setup? With a hose from the valve cover to the intake, and a PCV going to the intake?
Or are you doing it with a hose to a catch can with no vaccume applied to it.
matafied
no i had him remove the air filter and hook it back like the factory, he installed a oil catch can and hooked it on the intake side of the turbo. (behind air filter and maf) He did not have any issues after that
boomers04
Car: none
thanx everything is working great.
gawdzilla
Car: none
matafied wrote:ive seen this on a different turbo (sc61) on an rb, because of crank case pressure, motor was not breathing properly. this particular rb had a small air fiter on the valve cover and it got clogged up with oil and the motor started building pressure and caused oil to back up into the turbo and was burnning it out exhaust, so hope this helps
just read this... very interesting what you posted. i was doing a few drag runs once about 6 months ago, higher rpm.. running some crappy small valve cover breather filters on top vented to atmosphere.
saw some huge cloud of smoke come out the back of the car.
pull over, pop the hood, and see one side's valve cover breather filter is kinda soaked in oil and dripping a bit on my downpipe. i figured it was too much oil pooling in the head and sucking past the valve seals. compression check turned out fine.
what you posted above helps explain things.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I had the same thing happen to me after a morning of street tuning. The filter on my catch can apparently clogged with oil/moisture and prevented the crank case from breathing. Popped the filter off and it immediately fixed the problem. Kinda embarassing smoking profusely at a stop light before I was able to pull off and fix it.
matafied
boomers04 wrote:thanx everything is working great.
Awsome !! glad it worked out for you.
