gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Thu Jan 17, 2008 5:47 am
i did a LOT of research on this a few weeks ago. I was running a supra denso and the fuel pressure would drop off at sustained high boost. hardwired, i would say this pump is good to about 450 wheel. pressure starts to drop off beyond that. if you want to squeeze more out of the pump, you need to replace the thin wire in the connector to your pump's lid. I had mine hardwired, but in the end it was still using the 14ish gauge wire into the top of the fuel pump lid. The problem with the supra denso if you do some research is it draws a LOT of amps. everyone says close to double a walbro pump. i would suggest running 10 gauge wire ALL the way to the pump, which means running bulkhead connectors through the fuel pump access lid. Other than that, the supra pump is super reliable AND quiet.
I wouldn't run a walbro cuz of the horror internet stories. Most ppl avoid them cuz they've had bad experiences with them. They are cheap in price, and when they do work they seem to flow pretty well. I'd say they can do about 500 wheel by itself, simply cuz it draws less amps than a denso supra. i have friends that run walbros with success, but i always hear those "stories". And at $85 a piece... i dunno. if you've handled a walbro it is the smallest POS ever and just looks weak if that means anything. With that said, i would NEVER touch a dual walbro setup. One is already scary, but 2 just means twice the failure rate without you knowing until WOT.
Bosch 044 seems to be a great pump. It is an external but can be used internal, and flows rock solid. It's about the same price as the supra ($200). It is a PITA to fit though in tank because of its size.
Nismo makes a pump for the GTRs that is pretty baller and supposedly works awesome. Apex-i makes one for the GTRs and is often seen as the "top of the line" in tank fuel pump. That said, these two pumps are the most expensive. I think the Nismo is slightly cheaper, but the Apex pump is $399 online. I got a great deal on one so that is what I've replaced my supra denso with. I'm yet to do some pulls and monitor my AF compared to the supra pump, but i'll let ppl know my results. The Apex pump is bigger than the supra denso, so fitting is a bit harder. It is also LOUD, but if you look at flow numbers, it flows more than anything else and it draws very little amps.
Tomei / HKS/ Sard are also alternatives. Sard is the cheapest and I couldn't find any results of ppl running it. Tomei is slightly more expensive but not as much as Apex/Nismo. Might be a markup thing, but they might also just be rebadging a Denso. HKS seems to be a rebadged Denso pump, so it's basically no better than the supra oem denso.
the fuel pump you want to run really depends on your power levels. if you're sticking to < 450 whp, I'd go with the supra denso. If you're on a budget and cant afford the extra ~$115, go with the walbro and NEVER run it low on gas. If you want big power > 600 whp, you need to step up to the big stuff. Dual bosch 044 external with sump tank, dual walbro (if you want to risk it), aeromotive, etc. these are all tough to setup and usually requires completely revamping the fuel system. I'm running the apex because I'm maxing the supra and still want to keep the fuel system simple (stock lines, single pump). Supposedly it can be run to 600 whp but we shall see.
Modified by gawdzilla at 8:41 AM 1/17/2008
