Andrew85cm »
https://forums.nicoclub.com/andrew85cm-u11573.html
Fri Jul 15, 2005 9:22 pm
I guess potentially you could have stuff missing from your clip but the definition of a clip is the basically front half of a car. This often includes dash forward. Sometimes they include body panels brakes etc but often times not. The things you definately want are the ignitor chip, ECU, uncut harness, everything motorwise that you need, maf, intercooler etc. Make sure you have everything you need with compression and leak down tests done. I would be wary for ebay sellers but that is just me. I would rather be sure and go with a good company where you know you are getting a good motor that runs well with all the parts.~ANDREW~
