rb fpr
RBKIDD
Car: 92' RBsilvia
07' TBSS
i have an rb20, what kinda fpr will work and is easy to install
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
the nismo fpr is a direct replacement, you can get em from http://www.phase2motortrend.com i have one and it bolted right up to my stock fuel railheres the direct linkhttp://phase2motorsports.store....html
RBKIDD
Car: 92' RBsilvia
07' TBSS
thanks for the info,do you use the fpr in other words is it really necessary? do you adjust the fuel pressure alot by urself?
craz4240
Car: 1995 240sx w/rb20det
RBKIDD wrote:thanks for the info,do you use the fpr in other words is it really necessary? do you adjust the fuel pressure alot by urself?
Your gonna need one to set your fuel pressure with the high capacity fuel pump,also you can take your fuel injectors farther if you bump rail pressure.
RBKIDD
Car: 92' RBsilvia
07' TBSS
yea i have 75lbs injectors in it, also a gt3076r, z32 mas, 272 cams. i havent started it yet just want to get everything i need before i run it, thanks for the info again
240z4u
Car: '95 Nissan 240SX
What are you using for fuel management?
Evan
