RB finishing touches, Radiator, etc.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
I am getting my wiring harness back today from Mckinney Motorsports. I am going to try to install my side mount this weekend. So I have a few things left and could use your help.
1. I am using the stock S13 Radiator, so the bottom 1.75inch hose does not connect to the 1.75inch connection on the RB.
2. I need an adapter to fit a cone filter on the RB's MAF.
Before I spend all day convincing the Autozone guys to let me dig through there hoses, I figured I would ask.
Thanks guys.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
MY S13 KA24E HOSE FIT OVER THE RB OUTLET WITH ALITTLE CONVINCING. BUT IT WORKS.
I THINK THE Z32 IS THE SAME BUT I COULD BE WRONG.
NISMO_RB25
cool, have you had any issues with it. I am just a little leary of possible hose failure if I stretch it on there, but that is probably what I am going to try. What did you do for an Intake? Thanks for your help.
PROJECTRB240SX
NO LEAKS...THE ONLY LEAKS I'VE HAD WAS FROM THE INTAKE MANIFOLD GASKET.
frosted flakes
You can use a 240sx MAF adapter, just angle it a little and it will only work with 2 bolts. But this works perfectly.
Check out my rb20det in progress:
http://members.cardomain.com/funkycrzyshiet
Tony
PROJECTRB240SX
THATS WHAT I HAVE RIGHT NOW. THE PERSON I BOUGHT IT FROM SAID IT WAS FOR A RB20 BUT IT WAS JUST A KA ONE. IT WORKS BUT NOT PERFECTLY.
NISMO_RB25
PROJECTRB240SX wrote:MY S13 KA24E HOSE FIT OVER THE RB OUTLET WITH ALITTLE CONVINCING. BUT IT WORKS.
are you using the RB25 or RB20. I don't know if it makes a difference, but I tried this weekend, and I am going to have to use a different radiator hose.
Also, thanks for your advice about the intercooler, which I should have used, but didn't . I went ahead and installed the stock intercooler this weekend, and it must have taken me 6 hours! O well, at least it's done.
PROJECTRB240SX
I HAVE BOTH AND THE OUTLETS ARE THE SAME. THEY BOTH FIT.
NISMO_RB25
I greased the hose, and I still can't get it on there. I am going to try an adapter.
PROJECTRB240SX
I'M USING THE SOHC HOSE... IF THAT MAKES A DIFFERENCE?
NISMO_RB25
It might, I will look in to it. Thanks again.
