RB engine stand
wawazat8402
Car: 89 Sil80- RB25DET
I was just about to put my engine on the stand and started to flip through the FSM and noticed they had the engine mounted form the side.
Is this the only safe place to bolt the engine stand to or can I bolt it to the back of the engine like normal. I havent taken anything off the engine, but I dont think it will be too heavy for the stand (rated to 750 lbs) I am just worried about the strength of the bolts and the threads. The last thing I want to do is have the engine retapped because of stripped threads.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
My extra's are on the back. Just have to take the flywheel off and bolt them up. They have been like that for a long time. no harm no foul.
JonPowell
Car: Cars, Music, My family
EVERY motor I worked on I bolted to the trans threads. The stand from the factory allows you to access the rear of the engine for changing the rear main seal, thats all.
wawazat8402
Thanks. I was going to try it today and just watch very close for the bolts to flex, but this has reassured me. I will still be careful though.
dekand
Car: 1995 240sx SE
i bolted mine to the rear as well and it worked fine, no problems at all.
