mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Wed Mar 14, 2007 7:48 am
Sil240, the flex sections do two things, one like you say is to prevent damage from vibration & twisting like bottoming out the exhaust or the motor rocking during acceleration. This is the reason I want the flex on the main pipe (of course). But the flex sections also allow for thermal expansion, which apparently is an issue for the external waste gate dump pipe. The small dump pipe stays relatively cool while the gate is closed, but heats up rapidly as the gate opens. This causes the pipe to expand, and after enough cycles it may lead to a cracked weld at the dump pipe junction (expansion/contraction stresses the weld I guess). At least thats what just about every article I've read tells me.
Just pricing out the pipe, reducer, flanges, flex tubes and estimating labor I expect this dump to be fairly expensive anyways, so I don't mind spending the extra $50 or $100 to have the flex sections if it helps reduce the chance of destroying the part because I didn't use them.
O2 bung can go anywhere I guess; I was thinking it might see better readings a little further downstream where the gasses aren't as turbulent?... But I'll keep your suggestion in mind!
Yeah from what I see the flex sections are that flexible accordian tubing just wrapped with some kind of woven steel mesh. Still not sure what makes one flex section "better" or higher quality than another though?
Thanks for the input guys!
Modified by mello88 at 2:26 PM 3/14/2007
