Are you doing the labor yourself? or paying a shop to install it for you?S14toRPS13 wrote:Hey guys, I tried searching but got no answer. What should I expect to pay for a basic RB20 swap into a S13?
rb20 is cheaper, not the 25.Carl H wrote:rb motors are cheaper to get in and running but as you step it up it might not be so cheap...however prices on cams and the like have started to fall as of late, so its up to you really...
and when replacing the timing belt you need to replace the tensioner and idler pullies as well. the two in my motor were trashed and not replaced when the previous owner changed the timing belt. failure of either of those pullies means death to your engineblues14 wrote:make sure if you go rb that you do replace the water pump and t-belt before the motor is installed. my belt was ok, but my water pump was leaking out of the weep hole at startup.
