RB conversion parts inquiry
boostdesigns.com
Car: 95 nissan 240sx ka24de-t
i am curious to the demand of the following parts i have developed on my s14 with a rb25 in it for possible release on the website.
top mount tubular stainless manifold
3 inch downpipe with 38mm wastegate
3 inch exhaust
custom mounts to put rb in 240sx
i.c piping and intercooler kit.
t3/t4 57 trim
price will be 2500.00 for complete kit at this time.
any input would be appreciated i am also working on a liquid to air i.c for this setup and fuel rails and intake manifolds. thanks
Modified by boostdesigns.com at 6:44 PM 5/23/2005
Joe
manifold is a biggie, alot of the ones out now are eithre veyr expensive or very cheaply made
the downpipe may be an issue, people using mckinney mounts VS the stock crossmember need a different downpipe because of that. steering shaft clearance and stuff.
exhaust dont see a demand, 300$ at an exhaust shop for 3" DP back with muffler.
mounts depends on quality and what they do.
IC and piping is a big one for us.
id be interested in testing some of this if you are looking for test cars S14, Rb25, r33 crossmember and mounts.
boostdesigns.com
i deal closely with mike sims at top hat performance and use there mounts in the kit and its a perfect placement and fit and top notch quality as well. the parts i am making are going to be using these mounts and supporting equipment based around them. oh and i forgot to add that that price includes a t3/t4 turbo 57 trim. thanks
Joe
well like i said, you need to remember not everyone used aftermarket mounts, so while your topmount setup may work with your mounts and mckinney ones, it could hit the hood with a skyline crossmember setup.
boostdesigns.com
interresting so i need to keep the turbo around how high over the valve cover to work with the factory frame rail thats really all i need to know and i can adjust the design to work with both setups then everyone is happy
Joe
im not sure hard numbers but with the r33 crossmember and mounts you need to cut the hood skeleton around the throttle body and top intake tube. i think the engine overall sits around 1-1.5 inches higher.
SeVa-S13
Car: '05 GTO 6spd
Manifold-- T3, External Gate, Top Mount.
