rb coil retrofit question...
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Ok, so I got my coil in today...
I have connectors on the bottom with NO MARKINGS!!!!!!!
Which ones use power, which ones get signal?
There are no numbers at all on this coil...
On top, there is a symbol in one corner... That looks like a long = sign like so | |=== | |
So... Where do power wires go in, once I have that then signal should be easy...
mello88
Car: s13
Huh?? What car is the coil out of? Can you get a FSM for that vehicle?
BoostFab
Car: S13cp, S13fb, S14z
you of all people not using the search tool !zerothread?id=219934
Acecool
Yeah, I know about that thread.... it is from a buick skylark....
The diagram is NOT on those coils... also, mine does not have any info on the coil......... no numbers, nothing.. just that weird symbol...
BoostFab
all these wastesparks coils are wired the same. either pole is fine, just make sure it's like so on the same side throughout, so you don't confuse yourself
Acecool
Awesome, I have 12 gauge red wire for my power, which goes to the white wire.. then the grounds.. and 1 and 6go on top left, 2 and 5 on middle and 3 and 4 on right...
Going to fire her up in a couple moments :-)
matafied
Car: 1989 240 rb25det 1992 240 rb25det
lol yea but just to save you some heart ache, you need to reed the whole thread especially the part I put in their about upgrading that factory white power wire to a larger gauge supply with a relay. That little white wire has a hard time supplying them big coils at high rpm
Acecool
Yeah, read that a couple of times :-)
I am going to run another wire from that current one to another switched power source on a relay... already used 12 gauge THICK wire for on the coil, going to run another thicky to another source :-)
Josh
Oh and it fired right up..... just needed mainly to know if the poles were switchable :-)
BoostFab
Acecool wrote:Yeah, read that a couple of times :-)
Josh
that's great!!!! good to know it's working out for you. it's always best to run dedicated power and then activated by a relay; to give it all the juice it needs.
