WDRacing wrote:Its the oil pump thats bad, the RB25 can rev, its needs better cam profiles and a better intake. The cams and intake are designed for low end grunt.
WD
I figured it might have been the oil pan since I see a few companies make baffles for the 26s, but that makes since b/c most big companies wouldn't make high capacity oil pumps for just the 20 or 25 due to the low volume of sales (not exactly the in and out job of changing a pod filter).
It seems lots of the major parts you can buy for a 26 are also available for the 20 and 25 (other than turbos). I assume these parts were a byproduct of the 26's shortcomings discovered in its racing history.
