Darius wrote:Now that's even more strange. You don't have a boost controller OR a solenoid valve and it still only hits 5-6psi? Is that why you are swapping out gauges because you don't trust the mechanical gauge's accuracy?
I can't remember who it was, but they were running their RB25 without a solenoid or boost controller and I think the OEM wastegate spring opened around 10 psi.
It sounds to me like it either has a ginormous boost leak somewhere or the wastegate spring is losing its tension and just opens early.
nope the spring is 5.5 psi. its not possible to go UNDER spring pressure so if it was 10psi even with a boost solenoid or controller you would only be able to run 10 psi.
you are 3psi low on your pressure from the factory (that will account for a good 20hp). get a good boost controller and FMIC and crank that baby up to 12. i wouldnt go above 12 tho because they turbo has a tendency to explode randomly above 13 psi.
but dont expect the world, a GTP makes 260hp/280tq stock even tho its heavier and FWD its still a challenge for a stock RB25.
p.s. go to the damn track. street racing makes us all look bad.
