darkstar575 »
https://forums.nicoclub.com/darkstar575-u69765.html
Mon Aug 06, 2007 6:27 pm
Timing? Check the timing maybe your belt took a ****? I dunno...Realistically all your engine needs is spark, fuel, timing...Remove the cas and spin it you should hear your injectors clicking, or feel them click, aND YOU SHOULD HEAR YOUR FUEL PRESSURE SURGE TO THE FUEL LINES...Take a coil off and put a spark plug on it, spin the cas and it should spark...if you have both then check your timing...if you have spark and no fuel then you should be able to run it on starter fluid...if not maybe your eccs relays took a dive see if they are still clicking. Also make sure your wiring hasn't come loose or something. Once you try those things to the point that your 100% sure everythings on point then it could be something else. Usually backfiring is timing. What problems did you have while the car was running...maybe those problems lead to this...my rb20det hasn't even started, soooo I'm on the same boat, drinks for both of us since our engines are being gay! Good luck!
