Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Jun 30, 2004 7:12 am
SR == 4 banger, turbo, all aluminum engine. Came in the Silvias and the 180s. It's a good stout little engine with forged internals from the factory. There were three generations of the engine the S13 had a high flow head and a T-25 turbo. The S14 and S15 motors came with a low port head, but had VTC integrated into the intake cam. They both had T-28 turbos. They also had a revised water pump and oil pump design that improved cooling effeciency of the motor. The S14 had the strongest transmission of the group, and the S15 came with a relatively weaker 6 speed transmission. The S13 and S14 motors came with 370cc injectors and the S15 had been bumped up to a size that I can't remember.
Any SR is reliable up to 450 horsepower on the stock bottom end. I think secret services was pushing nearly 500 on the stock bottom end not too long ago.
The RB is an inline 6 motor that came in 3 sizes. 2.0 liter, 2.5 liter, and a 2.6 liter. The 2.0 liter was found in the cefiro and had one T-28 turbo. The 2.5 liter was found in the base skyline with a single turbo. The 2.6 was the GT-R's engine and came mated to a 6 speed, AWD transmission and had dual turbo setup. The RB is definitely a more stout block than an SR due to it's cast iron make (aluminum head), and takes to modifications easier than an SR. If I were building a car for straight line performance, an RB would be choice.
