RB AFM part #s
themadscientist
I researched the part numbers for someone who was short a flow meter and I want to share the info with all you guys swapping in J-spec motors. These are all the ones I could think you guys would need.
RB20DET(R32) 22680-02U00RB25DET(R33 early) 22680-02U00RB25DET(R33 later) 22680-31U05RB26DETT(R32) 22680-02U00RB26DETT(R33) 22680-05U00
Enjoy :)
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
You are the man! You might want to put these in the RB part sticky. It is kind of messy in there, but at least it is a central point.
Toad[^_^]
Thanks a bunch, but how do I know which AFM is right for the RB25 that I have? I already bought one :(
Fiendish
You need to identify if it's a series I or II.
I got those part numbers last week and called my buddy at Nissan parts to quote me on the RB25 series I AFM. It's about $240 USD with his discount. :(
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
How about RB20/25 ecu #'s? like how to tell if you have a auto ecu ect?
themadscientist
If you have a five speed it doesn't matter auto or five speed puter, I never change the ECU on transmission swaps. I don't know if it's true but I have heard the auto computers have a fatter fuel map.
Toad[^_^]
Fiendish wrote:You need to identify if it's a series I or II.
Explain.
Fiendish
Toad[^_^] wrote:Explain.
Sigh, search young Jedi. But for now and off the top of my drunk head......
A type II engine is newer and it’s got a better ECU on it. The wiring will be the same, but I think the way to identify it, is there will be 2 plugs instead of one at the throttle body.
The turbo compressor wheels are diiferent IIRC. The series I has an aluminum/steel wheel i think and the series II has a plastic wheel. This is the only advantage for the series I, as it can take more boost.
Correct me if i'm wrong, everyone.
goofynick6
Car: 1995 S14.5 RB20DET
My rb20det maf says 22680 16V00
What does that mean?
Nick
Fiendish
The following was taken from SON240sx.ca..
Quote »
Difference Between Type 1 and Type 2 Rb25DETS
Type 1 – Years 93-94
- Has one ignitor chip - Garret turbos with steel compressor wheels - Look near back of plate covering the plugs, black box with 2 plugs, one to the harness, one to the plugs (type 2 doesn’t have this box)
Type 2 – Years 95-98
- No single ignitor chip on plug cover, all integrated internally - Where a type 1 has a black box and 2 plugs, the Type 2 has a connector plugged into another connector - 2 throttle position sensor plugs on the throttle body - Nissan badged turbo with plastic composite compressor wheel, and ceramic exhaust turbine
Here are the years according the numbers on the chassis tags on the firewall. You can use this sheet to tell the year of your engine by the chassis plate number and thus whether it is type 1 or type 2.
[/quote]
Toad[^_^]
:oface Now I get it...:confused:
So if I have a series II what turbo should I upgrade to before I blow up my plastic fan.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
not really, the compressor wheel isnt exposed to the environment that the turbine is.
Toad[^_^]
Toad[^_^] wrote::oface Now I get it...:confused:
NM. I have a series II :ylsuper
Toad[^_^]
:( So sorry to hear that. I picked mine up for $50. Let me know if your interested.
Fiendish
Toad[^_^] wrote::( So sorry to hear that. I picked mine up for $50. Let me know if your interested.
That's used right? Either way i need a MAF. I'm eagerly awaiting cyris's email reply to see if he still wants to part his RB25 out. If it falls through, expect an email from me. Thanks man. :)
Fiendish
Ok, so Cyris sold his RB25 setup and i'm on the search again for a MAF for the RB25. Hook me up Toad. $50 sounds like a great deal, i won't be selling my soul right? It's already spoken for.
