I was reading and came across this...I am planning on putting in a launch controller, the gizzmo unit seems to be a legit way to go. Personally I dont like the idea of having a shift light in the car...is there a way to run the gizzmo w/o it? I would only use it at the track, and would want to dissengage it on the street, which sounds to me like all that is done thru the shift light?rb25drag wrote:yes you can do a burnout. The launch control is not activated until you activate it with the shift light.
it seems to me like its a dual purpose setup...to use it as a rev limiter, you have the clutch dissengaged, and upon rev limit, it cuts fuel and spark. for the 2-step function, it acts like a normal 2 step, letting you build boost by burning fuel etx.Darius wrote:That system looks more along the lines of what I'm looking for but I don't understand this part, "This system will cut both fuel and spark to the engine."
How does this work to spool the turbo if unburnt fuel is not present to ignite in the exhaust manifold? I understand cutting spark, but not cutting fuel. How exactly is it controlled? I need more details.
no it only cuts spark not fuel.Largekid wrote:it seems to me like its a dual purpose setup...to use it as a rev limiter, you have the clutch dissengaged, and upon rev limit, it cuts fuel and spark. for the 2-step function, it acts like a normal 2 step, letting you build boost by burning fuel etx.
i would only be using it at the track...it will help me launch better for sure. I am currently running a 275/40/17 MT radial full timerb25drag wrote:That ImportIntelligence unit has the same functions as the Gizzmo, It also looks to be cheaper!!
I personally like the shift light on the gizzmo, It really helps me to keep my shifts even at the track, ESP when Im bracket racing and it counts. BTW im the only Import 5 speed Know to bracket race around here LOL!!
But that was the whole point of the gizzmo for me, To be more consistent and make better times more evenly.
Now I haven't been able to cut any better 60ft's at the track using the launch control, Mainly b/c I keep spinning, So From experience, If you are not planning on running a slick then the launch control is going to be pointless!!
I have drag radials, BFG 275-50-15's I have run them at every PSI known, From 8-21 and I still Spun past the 60ft using the launch control. Bets so far was 1.78 60ft,
I have been 1.6 60ft without it.
It Really isn't a unit you can use on the street, I mean you can if you wanna do a Funny car burnout!! Which is cool in my book. But its really for the track use.
