RB 26 Transmission mounting to a RB25 Engine?
crashman1873
Car: Nissan Stagea
Does the RB26 transmission mount to an RB 25 engine without much or issue. And if so, what will I need to get it all set up correctly. This is for 1997 RS4 Stagea.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Not sure but guys who do rb26 swaps use the rb25 Trannys. So I would assume that the bell housing pattern is the same. I believe the clutch is a pull style on the 26 though or that might just be the newer one's
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
if its a RS4 stagea it could very well have the NEO RB25...and if thats the case its the same pull style clutch as the RB26 anyways...
crashman1873
Car: Nissan Stagea
Thanks
crashman1873
Car: Nissan Stagea
Thank you
Cjmartz2k
Car: Hunting for a '89 GTR now
I know somebody on one of my other forums (mostly US military in Japan) who put a RB26 transmission into his RB25 Neo (turbo of course), but dude kept it rwd for drifting Kinda a weird dude, but anyways I know if can be done.
SteveRB240sx
Car: 1990 240sx -R32 RB26Dett powered.
It should bolt up with out any problem, the bell housing on the RB25 trans and the RB26 trans are the same.
crashman1873
Car: Nissan Stagea
Thank you
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
is your stagea awd?? if not then the rb26 trans unless converted to rwd is not worth it.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
the 26 bell housing and 25 bell housings are the same, to convert your 26 transmission to rwd is remove the transfer case and cut the hump out n weld it shut. the clutch is pull instead of push tho
crashman1873
Car: Nissan Stagea
Thank you
