RB 25DET will not hold idle after warm-up and rev
[email protected]
Car: 1994 Nissan 240sx RB 25 DET swap
Hope someone can help me with this frustrating situation. My 240 SX with an RB 25DET swap starts perfectly idols nice and smooth from cold start to warm up but then when you rev it and release the gas pedal it will not re-catch the idle and it sputters and dies. I adjusted the throttle position sensor to read .48 V, replaced the AAC .
When I turn the AAC screw in and out it raises and lowers the idle as it should, but again, after fully warmed, when you give it a rev and release it sputters and die. When I start it back up it just chugs like it is starving , and I hear a "click click" eminating from what looks like a two inch long , large diameter hex bolt attatched to the head , towards the front of the car . It has a two wire connector attatched to it's end and that is where the clicking is coming from. I put an ohm meter on the throttle position sensor and at throttle plate closed I'm reading 1420 ohms and then when I open the throttle fully I am reading 8K ohms. Could that be the issue ?
I sure hope this sounds familiar to somebody have not been able to drive the car for sometime now thank you so much everyone.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Have you checked the ecu for any codes yet? have you tried unplugging the maf sensor and see if it will hold the idle?
