RB 25 DE Help
General discussion area for the U13-chassis Altima
altima95
Car: Nissan Altima 95
Hello everyone im new here and my first topic is im so in need for your help , experience and ideas
let me go str8t to the subject i have an Laural Altima 93 with RB25DE installed and KN air filter
now it sounds good but i would like to add more boost power and i was thinking of installing supercharger
so now what i need is your recommendation and advice
NolimitZ32
You have an RB25DE in an altima? Your altima came with a KA24DE transversly mounted 4 cylinder from the factory. The RB is a rwd engine and an inline 6 to boot which means you have a hell of an Altima.
Timothy S
Car: 1998 Nissan Altima GXE, Auto RE4FO4A, KA24DE Engine
Wikipedia Shows this engine was used in the Nissan Skyline, sold outside the US. Could you find a exhaust manifold and Turbo charger from a RB 25 DET, the turbo version of this V-6 engine?
altima95
hmmm i dont know, but i guess US have a different version of Altima maybe known for you as Cefiro a31 which comes with RB24s the one that i have and yes RB25DE and RB25DET engines are easily mounted without any modification on the engine base
but hell i made a mistake when i bought the RB25DE :( now i would love to boost its power to 300HP if its possible any ideas
Timothy S
Laurel altimas were sold outside the us, but are relatives of the Bluebird sold in the US as a 300ZX coupe with a rear wheel drive VG30DE and the Skyline based 2002 Infinity G 35 with RWD QR35DE. Both had v6 instead of inline 6 engines.
Are you in the US? If not, you might be able to add skyline or bluebird parts to your car. You might be able to find more help with a US based fabricator in the Nissan Z forum on nico club, or you could install universal fit parts to supercharge, or turbocharged your car. If you are up to the work, you might be able to make a new exhaust manifold to install a turbo if you want to go that way.
Unfortunately, I have never seen a inline 6 Nissan here in the US, so I do not have any experience to give you. I will try to post this in another forum and see how the response is.
Timothy S
rb25de-turbo-install-ideas-t599588.html
This will link to the thread in the Nissan Engine forum for this engine.
altima95
thnx a bunch mate ^_^ i will keep my eye if i found something usefull in other forums
Timothy S
We've got a reply on the engine forum thread!
Yellow4g63 wrote:I'm 99.1% sure most people in this part of the forum buy turbo motors already. Sounds like u need to just bolt it up tap oil pan for oil return, run a braided line to feed the turbo from a oil psi source. Get turbo injectors and blow up the motor after you get into to boost for the 1st time.
altima95
well then in this case im going to buy a whole new RB but what i would like to know which one is the best to go with
1- RB25DET
2- RB25DET Neo
and i mean for everyday driving
Timothy S
post6601199.html?hilit=neo#p6601199
This writer seems to agree with Wikipedia in saying the 1998+ neo engine is better than an older style rb25det. It is still all about price. if you can make do with lighter boost levels (under 10 psi), just add a turbo to your existing non-turbo engine. If you need a lot more than that, you might need to swap the engine.
altima95
well i didn't agree with anything yet , true that i have looked around but still im lack of information so that's why i posted my question here to get answer from the experienced ppl who tried both engines or one
altima95
Hello again
so finally i have RB25DET neo s1 without the Vtec big lump next to the CAS on the cambelt cover installed on my Cefiro A31 but i couldn't get it to work
RB25DET Neo
ECU No: E0
any useful ideas please help
thanks in advance
Timothy S
Standard checklist for no-starts:
Check spark or ignition timingwith a timing light, check for fuel pressure from the pump-do you hearit? And check for airflow sesors that might be disconnected or vacuum leaks.
My no starts always lead me to some wire somewhere I forgot to plug in!
One more thing: does the engine crank when you turn the key?
altima95
okaaay so i forgot to link some wires and i confess that was so dumb but anyway its working like charm now
except that i couldn't figure out how the Vtec suppose to work because turbo is working fine but i feel there is some hidden power still there any ideas guys and thanks for the help earlier ^_^
Return to “1st Generation Altima Sedan (1993-1997)”
