rb 20 on a rb30 block
weaponboot
Car: bmw 328ci
we have recently purchased a project from a person who gave up on it. rb20 head on a 30 block. the engine runs but only on 4 cylinders. we have tried the following replacements, cam angle sensor, module on top of head at firewall, i think this is ignition module , coil packs, spark plugs, coil pack wiring harness, could it be the computer, does it control the spark feeds individually from ecu to module. has anyone had this happen? help me , john in australia.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Hey John, your problem could be in numerous places. First check all the vitals: compression, injector pulse, spark, etc. on those cylinders that are not producing anything.
From there you can start narrowing down the possibilities. If you suspect its a coil swap them around and see if the problem moves to a new cylinder.
Testing out the CAS is as simple as pulling it out and turning the shaft to see if it sends the proper signal to each injector and coil. (Search for that one).
Spend about an hour looking into the problems from there take about an hour searching here to trouble shoot. Should get you going in the right direction.
Cheers!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Maybe he bent some of the valves.
weaponboot
Car: bmw 328ci
thanks, just found out today the computer looks like it is out of a ca18. 4pot. probably why we only have 4 running.doh.
