Vegascorbin »
https://forums.nicoclub.com/vegascorbin-u82093.html
Wed Jun 25, 2008 2:49 pm
Injectors can go bad in general two ways: electrical and mechanical
Electrical: The coil that causes the injector to open and close, (therby alowing fuel into the engine,) can open or short. Result no fuel.
Mechanical: The moveing part that actualy has to open and close to allow fuel to flow can brake, resulting in no fuel no matter how offten the ECU tells the injector to open. OR what I think is the more common mechanical problem, the injector mechanisam can get jammed open allowing maximum fuel delivery no matter what the ECU tells the injector to do.
There is not much you can do to prevent electrical problems. The mechanical problem are more preventable. Run clean good quality fuel. change the filter on a regular bassis. Use your favoite brand of injector cleaner from time to time.
NOTE: I am speaking only of the injector itself and also this is not an all inclusive list. It is intended only to assist the uninformed with some basic information.
