Q45tech wrote:Never seen a leaking fuel regulator on a Q, but anything is possible, assumming enough owner abuse..........or bad enough fuel.
The fuel pressure damper also gets its signal [vacuum differential] from one of the small hoses attached to the air house from rear of MAF to TB.
I forget which is which, but either the regulator or the damper is plumbed into the larger metal tube that runs to the AAC valve and the other has its own seperate metal tube that connects to the vacuum gallery hardlines.
