Raw Brokerage - S14 RB26 Build Thread
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
So I'm finally getting time to get out from behind the desk and under my car to begin building up my personal 1998 Nissan 240sx. Many may recognize my RB26 that’s been swapped in and out of some of the cars I’ve owned...
Our shop 350Z race car...
Being the owner of Raw Brokerage I guess it made sense to do something up for both myself and the company.
The goal behind the car is to keep it as streetable/ daily functional, while obviously getting some desirable performance out of it. This means that I won't be building a race car but a happy medium of fun and comfort for everyday driving.
Enough blabbing and onto some pictures (sorry for some of the water marking, can't find the originals of my older photos)…
The car was originally from Texas but I later purchased and shipped it down from Chicago.
Side by side with my brother's (240AceX) '98 Kouki with an R34 RB25 Neo...
Decided to start off installing some suspension bits and some BC Racing Coilovers…
A set of CCW Classics 18x9.5 for the front and a set of 18x11 in the rear were slapped on and aligned for good measure.
...but that didn’t last long as some idiots decided to jack the wheels off the car a month later :(
Oh well, back to stock wheels (replacements will come) and the decision to overhaul the car for some power…
The RB26 was built a few years back for another build of mine but changed my mind on the chassis to use. But since the change of events I've decided to drop it into my car..
Engine specs:
R32 RB26DETT (blue printed and clearance)
Modified RB26 AWD Oil Pan
R33 RB26DETT Crank Shaft
ARP Rod Bolts
ARP Main Bolts
Shot peened and cyro-treated rods
CP Pistons
Cometic Head Gasket
Tomei Type B Valve Springs, Ti retainers and keepers
Tomei lifters
SP Bronze valve guides
-12AN head drain
NGK Spark Plugs
Bolted on the intake side I retained the factory intake manifold setup and ITB’s…
Exhaust side for the time being wears a Full-Race manifold, T4 GT35R 1.06 A/R, Twin TiAl MV-S wastegates…
Fabricated a 4" downpipe coming off the turbo...
The front of the motor received a set of Raw Brokerage under driven accessory pulleys, 30% on the alternator and 10% on the water pump…
Also a 1500whp rated Ross Tuffbond MetalJacket and crank trigger wheel for the front of the crankshaft…
Now begins the car tear down…
The RB26 dressed with spare covers for test fitment
S13_RB25
Car: A 240 but no RB yet!
This is gonna be awesome!
Coolwhip
Vendor
flex pipe came in for the downpipe...
Razi
Car: Moo
That thing is gigantic!
Good luck with the build!
240TKE128
Car: 1990 240sx HB
2011 subaru outback 2.5i limited
Lookin Good, i would kill to have that kinda money so swing on my build.
Keep it up. :dblthumb:
alms24sebring
'04 Nissan Sentra SER SpecV
Once again, nasty looking build and even better for the personal car.
Cant ever go wrong with a white kouki and a RB with a giant turbo. Thats my dream car to have. *sigh*
Coolwhip
Vendor
Setting up the fuel system...
Deatschwerks in-tank
-6AN braided line out of the tank
Anti-surge tank
Bosch 044
XRP Inline fuel filter
-10AN fuel feed line
Twin -6AN into the fuel rail
1000cc Injector Dynamic Injectors
-6AN fuel return line
Aeromotive FPR
-8AN fuel return to the anti-surge tank
Mock up of the anti-surge tank in the trunk...
Madhatter969
Car: 95' SE s14 - build project
05' Evo VIII - DD
OHSHITYEAH! I can't wait to see where this goes!
m tr4nch
Car: RS13, Z31, P11
wow, looking pretty sick ricky! you gonna have that beast ready for totd next month? :naughty:
Coolwhip
Vendor
m tr4nch wrote:wow, looking pretty sick ricky! you gonna have that beast ready for totd next month? :naughty:
That's the plan. Won't be 100% at that time. But I'm driving it there regardless. So long hours ahead of me under this thing.
kouki munster
Car: 97 base 240
I'm going to eventually get a set of the classic CCW's for my car(been saying that for about 2 years now) and I'm just curious as to what offsets were you running because I'm planning on running similar sizes to what you had. (f*** thieves :tisk: )
jsturges18
Car: 1990 240sx hatch - totaled/parts car
1990 240sx hatch - replacement
2005 pt cruiser
2004 350Z
OMG those rims on that car <3 best ive seen on a s14
Caveit77777
Car: 1996 240sx SE
Sorry to hear about the wheels man. Any specific number that you're shooting for hp wise?
240sxAli4Life
Car: 1990 S13 Hatch SOHC... SOLD :(
1993 S13 Hatch DOHC!! Super Sexy!!
THIS BUILD IS GOING TO KICK a**! CANT WAIT TO SEE MORE!!! Keep up the amazing work... i guesstimate anywhere from 460WHP to 575WHP!!!
Mercury_Hg
Car: 1993 240SX Coupe
Caveit77777 wrote:Sorry to hear about the wheels man. Any specific number that you're shooting for hp wise?
I'm pretty sure he said something about 1500whp :gapteeth:.
Coolwhip
Vendor
Caveit77777 wrote:Any specific number that you're shooting for hp wise?
Going to tune for ~550whp to get to the Tail of the Dragon meet next month. Soon after I'll start cranking up the boost and hopefully max out this turbo down the road.
Coolwhip
Vendor
Was out of commission for almost for a whole week due to wisdom teeth being removed… slow progress on the car but still chipping away:
Motor is all bolted in on McKinney Mounts for test fitting and fab work to be done…
Drivetrain all buckled up with a one piece steel Raw Brokerage driveshaft…
Notice the use the modified RB26 AWD oil pan causes interference with the cross member and steering rack…
my solution: going to shim the engine up slightly and shave the pan down in areas of interference)
Coolwhip
Vendor
Test fitting GT35R and Raw Brokerage front mount intercooler...
Keeping the bumper beam... just making some modifications to clear the FMIC. Measure, cut, grind, weld, grind, fitted!
Ran the fuel lines to the engine bay... -10 AN feed, custom bracket to a -6 AN split for dual feeding the fuel rail and -8 AN return from the soon to be mounted Aeromotive Fuel Pressure regulator
Interior tear down begins... along with the auto to manual conversion
Madhatter969
05' Evo VIII - DD
Just a question for yah ricky, Would it not have been beneficial to run dual pumps to the motor from the anti surge tank? Just curious really, I am in the middle of piecing together my anti surge setup and was planning on running twin feed pumps/twin fuel rails. Correct me if i'm heading the wrong direction with that thought lol
Coolwhip
Vendor
Madhatter969 wrote:Just a question for yah ricky, Would it not have been beneficial to run dual pumps to the motor from the anti surge tank? Just curious really, I am in the middle of piecing together my anti surge setup and was planning on running twin feed pumps/twin fuel rails. Correct me if i'm heading the wrong direction with that thought lol
If you need more fuel going to the engine thats fine. Some people run 3 pumps.
Reason for my single inline pump setup is I later plan to install a small fuel cell on the other side for E85 and more fuel pump for that setup.
Hope that helps
Madhatter969
05' Evo VIII - DD
For sure, any new info to me is helpful in my eyes. Thanks and good luck with the build!
alms24sebring
Coming together nicely.
Coolwhip
Vendor
Interior is coming along, dash is pulled out along with some other interior trim to do the 5 speed conversion and the other interior wiring...
Ace test fitting the ISIS radiator and electric fans...
Radiator, intercooler, and bumper beam all installed...
Started to work on the custom power steering setup. Deceided to keep the AN fittings going and since I had to relocate the resisivor... mounted next to the radiator for a clean install...
Had to make some brackets... mounted to some factory threaded holes on the radiator support...
j-z
Car: 95 240sx
Hey man, I don't know if you remember me but I was at Matts shop a few months back and he brought me over to your shop because I wanted to check it out. I remember there was a black kouki s14 on your lift at the time, and you guys were discussing of angling the DP up towards the car.
Anywho, just wanted to say nice whip! I knew it was your shop from the first pic as I recognized your box, and the location helped too. I haven't been on NICO in I don't know how long. I just acquired my 4th 240, so that's the reason why I'm back. Take care man. I want to take my bike up to the TOTD! Got any spare room? ;)
alms24sebring
Looks like a closer than hell fit on the turbo..
S13_RB25
That resisivor is gonna get sucked in by that turbo lol!
240sxAli4Life
S13_RB25 wrote:That resisivor is gonna get sucked in by that turbo lol!
:werd: :biggrin:
RB26
Car: 1998 RB26 240sx- 710whp
2004 STi-536awhp
looks awesome bud. I sent you a PM about the fuel system. Let me know when you get a chance!
Coolwhip
Vendor
If the turbo sucks it in... it can have it. lol
j-z wrote:Hey man, I don't know if you remember me but I was at Matts shop a few months back and he brought me over to your shop because I wanted to check it out. I remember there was a black kouki s14 on your lift at the time, and you guys were discussing of angling the DP up towards the car.
Yea dude! Glad to see you back into the 240 scene... gotta bring it by. But yea, TOTD... you'll need to reserve a room or what not since our cabin is already full.
RB26 wrote:looks awesome bud. I sent you a PM about the fuel system. Let me know when you get a chance!
thanks man... i'll check it in a bit.
S13_RB25
Hey Ricky do you by any chance still have the engine harness and what not for that ka?? I might need!
