DeanM45 wrote:Just pull it out. Maybe an hour job at most.
Remove back seat.
Remove C pillar trim.
Pull out rear deck cover (just snaps in place aside from the two plastic plugs above the pass through).
Take out the 4 10 mm bolts, pull sub out.
While you have it out, dynamat the rear parcel shelf to prevent future rattles.
DeanM45 wrote:It'll be the same amount if not more work to try and "quieten" it. Fix it once, remove it.
PlatinumM35 wrote:I had mine removed when my sub was installed. You may or may not notice a little more sound from the trunk into the cabin. Also, while you have the rear deck apart it would be a good ideal to add some sound deadener.
