Rattling sound that has me stumped *Solved*
skiski329
Car: Nissan Altima Coupe 3.5
When i am at a long red light or anytime I press the break for a while there is a weird rattel. when i put it in neutral it goes away and if i put it back in drive it comes back. The same thing happens if i put it in park. i know the front breaks are really low and i need to get them changed. is it possible that the rattle could be coming from there? or the transmission? I wish i had more info but there is not much i can do since it goes away when it goes into neutral or park. any ideas what it could be or how i could gather more info?
Thanks!
Update, it was a pice of heat shield after geting a check engine light and the pathy was on the lift we just cut it off.
Razi
Car: Moo
Is the noise coming from the engine bay?
You should have someone press the brakes as you pop the hood and snoop around for the source of the noise.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Mine does this too sometimes. I think it might be an engine or transmission mount, but I haven't looked into the issue further. It seems more prevalent with the AC on.
skiski329
Glad i'm not the only one with this going on.
i've been trying to get someone to troubleshoot with me, but either i forget or run out time. I'm going to have to wait a bit now because it snowed quite a bit yesterday, and now it wont be as easy to slide under the pathy.
I'll try to get some video or other info as soon as i can.
cheers
zach7685
Car: 2002 Infiniti QX4
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
1968 Mercedes 230-Sold
2005 VW beetle Convertible
2001.1 Nissan Pathfinder LE
id bet anything on the exhaust shields
ltsnotme
Car: 1996 Pathfinder XE 4WD
zach7685 wrote:If Nissan Motorsports is Nismo.. Wouldn't Honda Motorsports be...?s
Honmo?
Towncivilian
Honmo?
I think it was meant to be "homo".
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
All Pathfinders I'v seen the exhaust shield clamp becomes unweleded from the sheild itself. Found a fix today for $1.20
Used sheet metal scissors to cut off old one. Rattle Gone! Sorry for any typos.
Chris.m
Car: 2001 Nissan Pathfinder LE 4WD
2001 BMW 530i
+1 on the heat shields.
I cut all of mine off.
I had a rattling at idle when cold and at 3000 rpm when warm.
Now it is perfect.
skiski329
zach7685 wrote:All Pathfinders I'v seen the exhaust shield clamp becomes unweleded from the sheild itself. Found a fix today for $1.20
wow! bonus points for the pictures! i'm going to have to drop by the store tomorrow and pick up a few of those clamps.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Take a magnet, make sure that magnet doesn't stick to the clamp or the clamp bolt. There are a lot of hardware store hose clamps that have a stainless band and a non-stainless bolt. It's pretty clear from the picture of the old clamp that the poster lives in salt country. You want an all-stainless clamp. If the HW store doesn't have it, try a chandlery like West Marine.
Chuck
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
Chuck Tribolet wrote:Take a magnet, make sure that magnet doesn't stick to the clamp or the clamp bolt. There are a lot of hardware store hose clamps that have a stainless band and a non-stainless bolt. It's pretty clear from the picture of the old clamp that the poster lives in salt country. You want an all-stainless clamp. If the HW store doesn't have it, try a chandlery like West Marine.
Chuck
I live in SC Car has been in SC all its life Not offroaded until recently and light at that. I'd say 87% of pathfinders have or will have this issue. Tractors supply is where i got it and it is stainless.
anstantanople
Yeah seems to be the heat shield. Do you really need the heat shield? I'm thinking of just taking it out. Would I have an consequences?
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
There was a lengthy discussion/thread on here re: heat shields a while back (1-2 years ago?), and the general consensus was that removing them was not a problem.
Mine fell off years ago (one at a time), and I've never bothered replacing them. No problems at all.
Hope this helps.
anstantanople
Yes it does, thank you!
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
My only thought is they are their for a reason and if its a quick fix they are staying.
