mksue3240sx wrote:Tensioner runs on oil pressure. Put an oil pressure gauge on your engine and check the pressure when the noise occurs. If your oil pressure is ok, probably time to pull your cover and redo the chains and guides tensioner etc...
airman86 wrote:what kind of rattling noisly where? is it harmonic? (as in, same/close pitch as what the engine is vibrating)
the reason i ask, is sometimes heatsheilds/other things can vibrate if their harmonic frequency is close to what the engine is vibrating at. i had an eclipse that did it only at ~2.5k rpm, and it was an exhaust heatshield. took the heatshield off, no more buzzing/rattling.
