Rattling noise when clutch pressed in
S14toRPS13
I don't know if it's the type of clutch I have, but I have a OS Giken super single clutch/flywheel. When the clutch pedal is pushed in, it makes a rattling noise. Everything seems to work fine except for the noise. From a little research, I read that the multi-plate discs rattles when the pressure plate is released, but this one is suppose to be a single plate.
Emperor_Tha
thats is wierd. When the pedal is not push down in neutral its either the t/o bearing or the clutches on twin disc. But for u its doing the opposite. Is this while driving or sitting still?
S14toRPS13
This happens mainly when I'm at a standstill. I've only test drove the car once. I don't remember hearing it while I was driving.
mofugger
Car: 1990-240sx ca18det sold 1995 240sx goin KA-T
if its a metallic chinging sound then it your clutch. i have a os giken too and the noise is from the plates ralting when theirs no pressure on them
S14toRPS13
Got it Thanks!!
dtowndrifter
Car: s-14 kouki
it supposted to make that noise i have a orc single plate...i like it ..my buddies hate it..
s14s14s14
Car: s13 and s14
yup i got orc its definately normal awesome clutch by the way and yeah my buddies hate the noise too
Jom
Car: 87 200SX SE
a friend of mine runs the same clutch and that sound imo is down-right appalling
S14toRPS13
I could put up with it. I'm just tired of the constant, "What's that noise?", "What's wrong with your car?"
S14toRPS13
Another question for those of you with OS Giken or similar type clutch/flywheels. Was it a PITA to drive around town. I feel like I'm learning to drive stick all over again. The most aggressive clutch I've had before this was a Exedy stage 2 but that thing drove like OEM. I'm getting more and more used to it but man I feel like an idiot.
Emperor_Tha
get nismo slave, suppose to give u a easier pedal. I would get one but cost way to much. Or u can adjust your pushrod out so u don't have to press the pedal all the way down
S14toRPS13
No, the pedal stiffness doesn't bother me. The clutch grabs really hard and the lighter flywheel drops in rpm pretty quickly. It's kind of tricky, but I'm getting the hang of it.
EazyBreazy
typically with any unsprung plate you'll have that rattling noise, i have it with my blitz clutch too, at first i was worried, but its been rattling for over 2 years now with no problems
unsprung plates also grab a whole lot harder, once you get used to it it's no problem, but it does take some gettign used to
