Rattling noise in rebuilt sr
Judas
Car: 240sx convertible air ride / Toyota Supra MKIV TT manual
I'm getting pissed of about this engine now. (because everything possible and impossible has done now)
I Have s14 sr20det (link below) and it has re-built engine, everything is new, only valves and crank shaft is old.
It has strange rattling noise @2500rpm... I try to get video or suondclip for you tomorrow. Noise is coming from head, I think :D
something information of the engine, Wiseco pistons, eagle rods, tomei 256/11.5mm cams, supertech valve springs and titanium retainers, acl bearings, ARP studs, GReddy head gasket everything else is oem parts, and new...
I've tried even other cams now, and engine has been in pieces now two times and everything is OK. even valves have been measured, those are equal length
Have you ever got faulty new rokcer arms, thats the last one I haven't tested yet...
If that does'nt help, I think I'm gonna use some dynamite...
corey240
Car: 1993 Nissan 240SX Base Drift Machine
did you ever figure this out? iv got the same thing, theres a video of mine in my thread with it.
karmakaze
Car: 98 240sx SE
2500RPM is about where the VTC kicks off. there was a thread a while back about this problem.
corey240
karma, check out the vid in my thread when its done optimizing, and tell me wtf my noise is
streetspirit7
Car: '97 240sx
I have a small rattle in the head of my S14 when I touch the gas pedal and when I release it. Rattle only last a second. Do you think that has somthing to do with the VTC
corey240
do you have the timing hcain guide in the head installed? you k now, the thing that hovers overtop the timing chain? if so, take it off and see if that fixes it, i didnt even put mine back in.
streetspirit7
Car: '97 240sx
Good call, I hadn't even thought of that. lol, I even had a similar problem on my KA and that fixed it.
