rattling noise from trunk area
[TYPE]SS
i got a 97 240sx. every little bump i hear rattling noise from trunk. i remember reading about it longg time ago. anybody know where the noise could be coming from?thanx
spoolthis
Make sure your jack is good and tight for one thing.
Mine's got a funky rattle back there. It sounds kinda like a belly dancer's finger cymbols. I haven't looked into it.
sheadee240
I'd be willing to bet that if you adjust the trunk latch on the lid side you will never hear the noise again. I just maxed mine out and its tight like a Benz now
turtl631
Car: S14
i have the same thing, like a constant rattle every time you hit any kind of road imperfection. ill try adjusting the latch, but mine is rusted :( the key won't even open it!
[TYPE]SS
sheadee240 wrote:I'd be willing to bet that if you adjust the trunk latch on the lid side you will never hear the noise again. I just maxed mine out and its tight like a Benz now
if u made a bet, u would've won~ no more rattling. can't believe how quiet my car is now. thanx man
KRUZNBY
Car: 95 240SX SE
I tried adjusting my latch, but it was already adjusted as low as it could go. I thought maybe the spoiler was vibrating, so tightened it a bit, but I still have a rattle. Maybe it's rear deck. I need to have somelse drive while I ride in the truck to find out.
turtl631
Car: S14
how do you tighten the latch? I'm guessing I can't do it cause mine is rusty...time for some pb blaster
hotshot240sx
Car: my 240sx
check the clip that actually locks the trunk if thats tight..then check the baffle in the gas tank my friend...they do eventually break...and will cause a type of rattle...but check the clip on the lock assembly...
jsr
Yea how do u tighten it? pics would really help my dumbass out hehe. My trunks been rattleing since i got it. Now with the 15 it's just too much.
sheadee240
Do you mean as low as it goes or as high as it goes?
Tip...Higher is tighter, lower is looser!
KRUZNBY wrote:I tried adjusting my latch, but it was already adjusted as low as it could go. I thought maybe the spoiler was vibrating, so tightened it a bit, but I still have a rattle. Maybe it's rear deck. I need to have somelse drive while I ride in the truck to find out.
KRUZNBY
Car: 95 240SX SE
^Low as it goes. Only the 'loop' part appears to be adjustable. The latch mechanism on the lid is in a fixed position. I assumed the lower the loop, the tighter the truck lid right?
edit: just saw your tip. Really? I'll give it a try.
sheadee240
Open trunk.. look under lid for latch ...loosen fasteners a little... push latch slightly higher (towards the sky)...Tighten... recheck
KRUZNBY
Car: 95 240SX SE
sheadee240 wrote:Open trunk.. look under lid for latch ...loosen fasteners a little... push latch slightly higher (towards the sky)...Tighten... recheck
Wait, now I am confused. On my '95 s14, the latch on the trunk lid is not adjustable, only the loop above the bumper is.
sheadee240
KRUZNBY wrote:Wait, now I am confused. On my '95 s14, the latch on the trunk lid is not adjustable, only the loop above the bumper is.
my fault poor memory
240SXer
Car: 1995 240sx SE (2jz powered)
Mine rattles like a biatch too, i'm going to try adjusting it, even thought I don't know how. I'll just start d!ck with it. :)
entity
I rigged it by taping the loop with some electrical tape. No more rattle.
SunshineAcid
Car: 89 240sx Ka24de swap
two of the cars ive driven had rattling trunk/hatches.both times it turned out to be exhaust.
