Rattling front passenger door speaker
sileung
While I was driving today I noticed a rattling noise coming from passenger side. This only occurs when I hit a bump or driving on rough roads. It sounds like plastic hitting on plastic.
At first I thought it was coming from the glove box so I took everything out and had my girlfriend hold the door shut but the sound continued.
Later we pin pointed where the sound was coming from and found that it was the speaker area on the passenger side door. It seems as if the speaker is loose and banging around inside.
Has anyone has this problem before? If so, what did you do to fix it?
sileung
Update
Now when I sit in the passenger side, I hear the same noise coming from the drivers door speaker area.
Return to “Rogue Forum”
