rattling from valve cover on 89 ka-e
DrifterXRPS13
Car: 1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600, 2013 Harley Davidson Iron 883, 2014 BMW S1000RR
i have a rattling sound coming from the front of my valve cover, i can hear it at idle and when i rev it, when i'm driving though it's less of a problem...i don't hear it that much at all....mostly at idle, and low rpm.
i've taken off my valve cover to replace the gasket and looked at the inside of the valve cover and there's no damage to it nor is there anything out of the ordinary...i keep wondering if it's the timing chain itself or is it a guide which seems to be the problem with most ka's.
i've had this problem for well over 6 months maybe even a year if i remember correctly.
it drives fine but it's a little slow from a dead stop.
SMoKeM240
Car: 89 240sx NA/KA
mine did that and it was the exhaust side chain guide, look the see if half is broken off, also if u can move the guide around, its done for, and time for a rebuild
PureInsanity
Car: 89 S13
Welcome to the joys of owning a 24E. Also check the lifters in your rockers. Somewhere on here theres instructions how to Im sure.
godspeed
dude, pull your valve cover agian, and check how tight the chain is, this is my porblem, i am changing the timing set today, if this is it, then you could jump a tooth and jack your head up, mine used to do it at start up only, but now does it all the time
