HwnStylin »
https://forums.nicoclub.com/hwnstylin-u10810.html
Thu Apr 15, 2004 2:11 pm
Ok, i've got this rattling/ clicking noise coming from my engine. i've had a couple suggestions already that it could be my timing chain or my timing chain guide. The noise only happens when i'm driving, and i'm trying to keep an even pace. when i push on the throttle more to accelerate, the sound goes away. when i let off the throttle to slow down, the sound goes away. also, this started happening after i went about 115mph. i'm not completely sure that its the timing chain because the noise does not sound like its coming from the front of the engine, but more around the 1st cylinder, exhaust cam side. when i rev the engine when i'm idling, the sound only happens around 2500 to 3k RPMs. i've taken off my valve cover and looked around for anything not normal, and the only thing i noticed is that the timing chain has enough slack on it to hit the upper timing chain guide. as you can tell, i'm very confused because it did not sound like it was coming from the front of the engine where the timing chain is, but i dunno. maybe it is the timing chain. anyways, any help at all or any advice would help out a lot. thanks in advance.
