wantz87 wrote:it's the idler bearing on the input shaft inside the transmission. no ifs and or buts about it, theres no way to get rid of it without a rebuild.
A similar noise was there before that would occur at the same point in time but the pitch is different and its louder now. The original noise was there when I got the car back in '97 at 38K miles. If the transmission needs to be replaced then I would say the 240 transmissions are bad.. no transmission should ever be replaced that soon and I don't really even drive it that hard.
I have had a lot of problems with this car and its very clean and was clean when I got it. At this point I probably will not by another Nissan. My parents have 2 hondas and have never had a single problem with them. One is now 9 yrs old and nothing besides just maintenance. I just got done doing the rear main seal with the clutch. I replaced the crank and oil pan seals 2 and 3 times now respectively. They were first done in '99. Car was only 4yrs old then.. Sorry, but I don't get it!!
