Rattle midcar in exhaust
89gunit
Car: 2008 Infiniti M45x
I have a really loud noise that started couple days ago on my '08 Infiniti M45x with 184 thousand miles. It stays the same noise when accelerating. No clue what it could be. Help!!!!
Reason: Moved to correct forum
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Heat shields at many positions around the exhaust tubes have a tendency to fall off over time due to rust. They can make lots of rattle noises until they do finally fall off. Stainless steel band clamps can often be used to secure these loose pieces or replacements might be available.
PapaSmurf2k3
Site Admin
Yeah, you're gonna have to get under there and start pounding/shaking some stuff with your hands and fists to see what might be going on.
EniGmA1987
Car: '06 Infiniti M35 Sport
Could be a heat shield, could be your cats went bad and a chunk of the honeycomb started travelling down the exhaust, could be a section rusted away and the pieces are ratling up against each other.
Anything it might be, best to simply get under the car and look at things and try shaking stuff and see what is loose.
MM...Good
Car: 2006 M35x - totaled :(
2007 M35X - Rein"car"nated!! Premium, Advanced Tech, Journey and Aero Package
2013 G37 Convertible - SOLD.
1993 Miata - Zoom Zoom
1999 Honda Shadow Aero 1100
Agree its likely just a loose shield. I just fixed mine on the driver side right at the Y pipe. $2 fix with a steel clamp. Noticed the shields on both my cats are basically rusted through. No rattles though. My baby is getting old!
L5211
Car: 2006 M45 Sport Diamond Graphite, Journey & Tech pkgs
Mine did this too. Heat Shield. Cheap fix at mechanic.
