jimbyjimb »
https://forums.nicoclub.com/jimbyjimb-u93878.html
Fri Jul 04, 2008 5:06 am
I have a rattle under my car, sounds slightly right justified, hard to tell if it is front or back and can only be heard with the windows down. It is not a clunk, it is definitely a rattle. I've been under the car several times to try and find it and here I stand: All steering components tight, boots on rack broken but won't rattle so nothing there, front wheels/brakes/rotors tight and do not shake, rattle or loosen with pulling/shaking/kicking/turning/biting...er, Calipers tight, all front suspension hard parts tight with seemingly good bushings, flex hoses good and tight, strut boots are broken and struts are possibly suspected though I would expect a different noise from them and they seem to be in good working order without excessive roll or bounce and I cannot duplicate the rattle manually with them, the cats don't seem to be rattling and everything around the transmission/driveline upon inspection/beating seems tight and in good order. I haven't done as thorough a job in the back yet, but the wheels/tires/brakes seemed fine when inpected/beat also. Is there anything that is a common cause of rattle under the first Q's? I've searched through the threads and came up with cat mounts, but those seem to be just fine, are tight and in good condition. Any more suggestions no matter how small would be greatly appreciated. The rattle drives me nuts since the car is in perfect working order EXCEPT for this rediculous rattle. The rattle only occurs on rough surfaces/bumps and not on smooth freeway surfaces. Thanks alot!
