Alfador »
https://forums.nicoclub.com/alfador-u28926.html
Tue Jan 24, 2006 5:42 pm
Some areas have these dumb teenage gangs who think its funny to pull stupid pranks like throwing a couple marbles into someone's gas tank. Easiest solution is to remove the gas tank (I believe a service manual has how to do that), drain it, and then dump it out. Just make sure to follow proper combustible handling procedures like a static free environment.
Note: it could also be some odd component, in which case a garage magnet might work if you can keep it off the sides of the tank.
