Ok, now the block off plate would go at the back of the intake manifold, and for this valve on the exhaust manifold I have read you can buy a bolt from nissan or somewhere that will seal it up.240Tham wrote:It looks like your EGR valve. It's there to recirculate gas exhaust back to the cylinders. You can block it off with an EGR block off plate or cut some of it and clamp a hose between it.
