lemon »
https://forums.nicoclub.com/lemon-u86429.html
Fri Jun 25, 2010 1:58 pm
i searched, and ive read the diy but im just double checking since im laying down a color instead of flat black
does this sound right?
im going to be using all rustoleum products
step 1: wash and let air dry
step 2: sand with 400 grit paper
step 3: wash, dry, degrease, dry
step 4: prime
step 5: sand with 600 grit paper
step 6: another coat of primer
step 7: sand again with 600 grit
QUESTION ! should i let the primer completely dry ( like 3 hours ) between coats, or should i just lay it down after it fllashes ( sticky to the touch ) ?????
step 8: lay down first 2 coats of paint
step 9: wet sand with 800 grit
step 10: lay down another 2 coats
step 11: wet sand with 800 grit again
step 12: do final coat of paint
step 13: wet sand with 1000, 1200, and 1500 grit
QUESTION ! should i use a clear ? color is going to be red
step 15: spray 1st coat of clear
step 16: wet sand with 1000 grit
step 17: spray 2nd coat of clear
step 18: sand with 1500 grit
step 19: compound
step 20: wax
sound like that'll turn out good?
