Khronik »
https://forums.nicoclub.com/khronik-u162458.html
Wed Jun 16, 2010 5:52 pm
getting a rattle when in gear and not applying the gas, im thinking its the heat shield or the ?insulator casing? around the exhaust pipes, had the rattle in neutral the other day got out and could see the casing bouncing maybe the bolts are loose will check that out after she cools down
was also a sort of hissing sound coming from the back of the car near the wheels, sounded like it was coming from the caliper area kinda sounds like an idle static coming from speakers or a pressurized air coming out of a hose sound
any ideas?
