knelson »
https://forums.nicoclub.com/knelson-u233110.html
Fri Sep 01, 2017 8:40 pm
Well a simple bolt on project ended up being a huge pain in the butt today. I went to install the infiniti sports exhaust which is just a muffler and exhaust tip swap with the stock. And while I'm in Texas, the car spent two years in New Jersey and there's rust underneath in some areas. The bolts holding the exhaust pipe to the muffler were seized so I fought with them for hours. I eventually had to cut one bolt out. Finally I got both sides almost finished. (Besides now they aren't even and I need to do some adjusting tomorrow, although even this was a nuisance because they were factory specs, used the same hangers and everything, but after installing they aren't the same height.)
My question is, now I'm getting a rattle from the middle of the car... seems like under the drivers seat. And the rattle is only when there's. Load on the engine... not in park, but under light acceleration. I'm wondering if as I was cutting, or more likely hitting with a screwdriver and hammer on the back driver side to break the really problematic bolt, could I have knocked something loose all the way up toward the cats?
Any thoughts?
I'll get back out there tomorrow and investigate. But I'm not sure I can figure this one out without a lift, I might have to go to a muffler shop to help me diagnose.
