s13sr20chris wrote:i was thinking of optimal camshaft setups for sr20det's. obviously just bench racing like this will not prove anything but lets speculate. people with small stock turbos running max boost seem to not gain power with camshaft upgrades. i have read that is because you cant run cams with significant overlap unless your turbo has a good size turbine. to go further, i understand that once you get into crossover you can run cams as big as an na car. this leads me to think the intake cam may be outflowing the compressor(or something like that). makes sense right? sooooo, if using a small turbo(stocker or mild upgrade) why not just upgrade the exhaust cam to give the engine maximum exhaling but not messing with the intake.
1. The cams have to be matched properly with the engine. You know this, and most people know this, but not alot of people understand it.
IE. Running 272's on a stock valvetrain motor that operates from 3000 - 7500 RPM is wasting powerband.
2. The SR engine is very picky about cam timing (similar to the 2JZ in this aspect). In my opinion running cams without cam gears is like buying un-adjustable suspension. Timing the exhaust valve opening is CRUCIAL for a smooth powerband, especially for the larger cam'd engines where you can dial out some of the overlap.
3. Stepped cams - alot of this extends from Japan. People running 264 intakes with 272 exhaust cams to maintain some low end flow with the top end from the 272. The issue I see with this is that the valve openings become scattered from the varying durations and lift patterns aren't the same. I find this to be mismatched. I don't have alot of proof to back this up but I don't think it follows the flow pattern very well as cams generally are ran in "symmetrical" pairs in most engines.
However in the SR20VE the camshafts are ran with variations in intake and exhaust durations and lifts. You might want to look there as the SR20VE is a very efficient engine and the head design has proven itself so far.
You might also look further into the differences used between the SR20VE and SR20VET engines, but bear in mind that the VET must spool the turbocharger in order to provide low in response, whereas the VE relies on it's high compression ratio.
