Rasdiator Leak Fix, Is there anything other than new one for $250?
Soravia
Car: 2003 Audi A4 1.8T
I broke my first car's radiator from a head on collision and the second 240 coupe I just got have a radiator I'm suspecting has a leak. I had some fluid spills on the ground the other day. (I had plenty of spill when heater wasn't hosed up :P)If there is a leak on near the top of it how can I fix it? Will an electric welding work?
Thanks
480sx
Car: 1996 Pearl White 240sx
No you need to replace your radiator. You would never be able to get a good enough bead on the hole, it would heat up, expand, cool down, contract, and eventually pop back off anyway. Radiator stop leak is a bad move too, as it has the nasty habit of clogging your heater core valves.
First make sure its leaking though ^^
killablue240
Car: sr powered s13 coupe, 1991 twin turbo 300zx
i bought a s13 radiator for 100.00 shipped to my door spfand a s14 for 120.00 shipped to door. look in your yellow pages under radiator there should be a company with a 800 number.
