RAS, Slip, VDC Off lights on
M45_Mop
Car: 2006 Infiniti M45
Hello guys anyone know how to fix this issue. Those 3 lights always come on as soon as i drive the car and they stay on. My brake fluids are at max level and i did rotors and pads last year at this time. I took my car to my mechanic and had the codes pull they were C1137 RAS Circuit C1185 ICC Control Unit C1109 Battery Voltage
Ilya
Hi there.
There are countless threads for this issue with a myriad of suggestions. Please search for "RAS Slip VDC lights".
Could be the camshaft sensor, etc.
M45_Mop
I replaced one of my camshaft sensor only cause the check engine light came on. And those 3 lights are still on
Costee
Car: 2006 Infiniti M45 Sport
2012 Nissan Murano SL
M45_Mop wrote:Hello guys anyone know how to fix this issue. Those 3 lights always come on as soon as i drive the car and they stay on. My brake fluids are at max level and i did rotors and pads last year at this time. I took my car to my mechanic and had the codes pull they were C1137 RAS Circuit C1185 ICC Control Unit C1109 Battery Voltage
I'll check that battery over first. When it's dying it has a way of throwing C codes.
M45_Mop
My battery is not even 3 years old? I checked my battery and it is fine
BlackCat81
Car: 2006 Infiniti M35x
2003 Lexus GX470
If you can hold off until Tuesday when I'm back at work, I can help you out. Just be patient and I'll respond back.
M45_Mop
Ok Blackcat thanks can wait to see what you have to say.
njjuliano
Car: 2010 M45X
I had similar lights, and it wasnt the fluid or the pads. Mine was a result of the leveling sensor of the steering wheel. They fixed my seat sensor in a previous job, and they didn't replace the sensor properly.
BlackCat81
2003 Lexus GX470
Sorry dude, came down with walking pneumonia and have been out of work all week. Won't be back until Tuesday.
ayjay23
Car: 2006 M35
2013 m35h
Any solution yet? I just threw C1137 and C1185 myself. Nothing other than CEL is on though.
BlackCat81
2003 Lexus GX470
It'll be a while before I can check the FSM, Thursday was my last day of work and I'm moving across the country in a few days.
Poirot
Car: 2007 Unbria/Bourbon M45 Sport
Quick question... If one camshaft position sensor goes bad, should both be replaced along with the crank position sensor? Just to take them out of the mix for potential future failure? My code is P0340, camshaft sensor bank 1.
Costee
Your M45 has only one camshaft sensor.
Poirot
Costee wrote:Your M45 has only one camshaft sensor.
I stand corrected. Rephrasing.... Should I replace both the camshaft sensor and the crankshaft sensor at the same time?
Poirot
Costee
Poirot
Nice idea. Both are in fact the same.
