RAS, SLIP, VDC, camera guide lines off on 2006 M45 [SOLVED]
rondabigmon
Car: 2006 infiniti m45
Hey everyone, im new to this forum. I just picked up a 2006 m45 sport. Iv been serching a lot about this problem but I cannot find an answer. My car has the ras,slip and vsc lights on. But when I first start the car that are not on. If I turn the steering wheel back and forth, all those those lights will come on at once. And the active steering light will be blinking untill I shut the car off agian. I have changed the brakes and added brake fluid. Still the lights remain on. I did notice when I do the camera system check. The steering position sensor will read "ok" on the first time I move the steering wheel, but then when I turn the steering wheel the opposite way, the steering wheel sensor will not read anything.
Also when I put the car into reverse the guide lines on the back up camera is way off. Does it sound like I just need to replace the steering wheel sensor?. I dont want to be buying parts and then it not be the problem.
Also, I plugged the scanner in. And the only code is for a bank 1 sensor 2. I don't think that will cause any of the lights.
Anyone ever experience this before?
Reason: updated title
svard75
Car: 06 M35x
Just to clarify when you turn your steering the rear camera lines only turn towards one side? Yes it sounds like the steering sensor is malfunctioning or it could simply be the contacts. Try to disconnect the sensor and check for signs of corrosion. The bank 2 sensor could be a different issue. I seem to recall another recent post with the same problem and it ended up being a sensor issue. Search the forums.
rondabigmon
When I put it in reverse the backup camera guidelines will not be in the correct position. The will be pointing to the left. And when I move the steering wheel, the lines will stop moving and then all the lights will come on. The steering wheel dies have a little play also. It feels like the steering column is a little loose. Tomorrow I will take it apart and check the connections
GQM45s
Car: 2008 Infiniti M45 Sport Tech Pkg, Advance Tech Pkg, Mobile Entertainment Pkg
You can go into the diagnostic tool in the nav to adjust it, I believe it might be in the FAQ, but those lights, have you checked your brake fluid level, might need to top it off
Costee
Car: 2006 Infiniti M45 Sport
2012 Nissan Murano SL
rondabigmon wrote:I just picked up a 2006 m45 sport...My car has the ras,slip and vsc lights on. But when I first start the car that are not on. If I turn the steering wheel back and forth, all those those lights will come on at once. And the active steering light will be blinking untill I shut the car off agian. I have changed the brakes and added brake fluid. Still the lights remain on. I did notice when I do the camera system check. The steering position sensor will read "ok" on the first time I move the steering wheel, but then when I turn the steering wheel the opposite way, the steering wheel sensor will not read anything.
Pls, how is the camera system check done? As for the codes, I want to believe you used a scanner that could read the ABS module. If not you'll get only the PCM codes. I once had this issue and it had to do with alignment adjustments.
rondabigmon
You can check the camera system but turning tue radio off, hold the setting button and turn the volume knob. Some options will appear on the navigation screen. And you can check is sensors are working or not.
Well I checked the connections on the steering angle sensor. And they were all good. I plugged everything back up. And still the same problem. When I first start the car, thier are no lights on. If I turn the wheel all the way to the left or right. All the lights will come on at tue same time. I do not have to be in motion. This all happens while the car is still in park
Costee
rondabigmon wrote:You can check the camera system but turning tue radio off, hold the setting button and turn the volume knob. Some options will appear on the navigation screen. And you can check is sensors are working or not.
Done. Thanks.
DeanM45
Car: 2006 Infiniti M45 Sport 1 or 2 mods
Sounds like someone turned the clockspring with the wheel off and you are out of alignment.
This is the way I fixed mine when I had a similar problem:
Make sure the front car wheels are straight.
Pull the steering wheel off.
start the car.
Put the car in reverse and adjust the clock spring (move the little nipple on top that goes into the steering wheel--ONLY MOVE IT AS MUCH AS NEEDED) so that the "reverse lines" on the screen are in alignment and green.
Turn car off.
Disconnect battery and wait 10 minutes.
Center the nipple on the clock spring to the top, there are also alignment marks on the clock spring at about 7 o'clock.
Put the wheel back on.
Reconnect the battery, you will have to reset the airbag light (because of starting the car with the air bag disconnected).
Everything SHOULD be in alignment now.
This is of course assuming that the clock spring is not damaged in some way.
rondabigmon
start the car.
Turn car off.
I will try this tomorrow. When you had this problem, were the slip, ras, vdc off and afs lights on?
DeanM45
Yep, all lights on. This all happened when I was first installing the paddle shifters. If the battery is connected and the clock spring is moved AT ALL it will throw alignment off.
rondabigmon
DeanM45 wrote:Yep, all lights on. This all happened when I was first installing the paddle shifters. If the battery is connected and the clock spring is moved AT ALL it will throw alignment off.
Thanks a lot. That makes a lot of sense. Theres a possibly it can be damaged. You think I am better off just buying a new steering wheel off ebay ?
DeanM45
No, it is not the steering wheel. It is the clock spring which is a separate piece. Try what I posted above first and see if it fixes the problem. Clock springs are not cheap.
rondabigmon
Thanks a lot. That makes a lot of sense. Theres a possibly it can be damaged. You think I am better off just buying a new steering wheel off ebay ?[/quote]
No, it is not the steering wheel. It is the clock spring which is a separate piece. Try what I posted above first and see if it fixes the problem. Clock springs are not cheap.[/quote]
Ok ill do that tomorrow. But are you saying I take off the entire steering wheel?. Or just the part that holds the airbag? .I had the steering wheel off yesterday. I dont remember seeing a knob to adjust
DeanM45
Pull off airbag and then the steering wheel. There is no "knob". You'll be staring at the clock spring mechanism. About a 3" donut looking thing with a nipple at the top that fits into a hole on the top of the steering wheel just above the steering shaft that the wheel is bolted onto with a 17mm nut (or 19mm, can't remember). Do NOT just spin it around, you will break the internal mechanism. Little movements are fine (to re-align it) but don't just sit there and spin it.
rondabigmon
DeanM45 wrote:Pull off airbag and then the steering wheel. There is no "knob". You'll be staring at the clock spring mechanism. About a 3" donut looking thing with a nipple at the top that fits into a hole on the top of the steering wheel just above the steering shaft that the wheel is bolted onto with a 17mm nut (or 19mm, can't remember). Do NOT just spin it around, you will break the internal mechanism. Little movements are fine (to re-align it) but don't just sit there and spin it.
I just finished doing this,and it appears you were right. I lined everything up. Drop the car around the block. Everything was fine. The traction control was working no lights came on. Thank you very much! :)
