RAS installation broken bolt/stud
Dongoesby
So I broken one of these while torquing the bolt/studs.
I know I used a wrong torque wrench that is can not work on a small amount of torque. I'd like to know if KA24DE is using the same stud size so I could get one from the dealer quick. Thanks.
s13-t
Car: s13 pig nose w/blacktop sr20det
well you didnt say its an s13 sr but it looks like it so... I would recommend asking for a sentra sr20de cam cap bolt. Make sure you take them a pic or tell them its the exhaust side, second cap, inner bolt, remember the baffle plate as that bolt might be longer than the others to compensate for the baffle plate.
