Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Aug 26, 2004 11:54 am
the guy that swapped the motor into the car routed the heater hose so part of it covers the rear left corner of the valve cover. It makes installation of the valve cover a PITA. I need to get back there and cut the hose shorter, but I'm too lazy.
Also, it sucks when you get all the nuts started on the cover and realize you can't find one of the metal discs that cover the last rubber grommet. Then when you can't find it, you get paranoid and pull the valve cover to find it lodged in the head.
